Importing from P3 to MSP
Carlos Arana
User offline. Last seen 6 years 6 weeks ago. Offline
Good day,
I’m trying to import a P3 database into MS Project but i’m not getting good results.
I tried exporting the P3 data to an XLS file but that way I can’t import relationships, then I tried using the P3 to MPX tool included in P3 but it did not export many relationships and the actuals before the data date.
Any hints?
Carlos.
Hemanth Kumar
User offline. Last seen 1 year 16 weeks ago. Offline
Oops Import to P6, then export to MSP
Hemanth Kumar
Import to P6 Export to P3 !!
User offline. Last seen 1 week 1 day ago. Offline
http://www.eh.com.au/Technical%20Papers/030804%20Converting%20to%20and%2...
Generally no two PM software tools will provide the same answer. Especially if you have been using SS and FF links between two tasks (for example Ladders and Hammocks), because MSP cannot do that, so you are bound to get a different answer.
Carlos Arana
Thanks Rodel, But I have a P3 database to start with and want to convert it to MS Project.
Carlos.
User offline. Last seen 20 weeks 1 day ago. Offline
Carlos,
Check your MSP and the link maybe on Summary Task and check Project Information and make sure it has the correct data date before converting to MPX then convert to P3. (Note Higher version of MSP doesn’t convert MPX only MSP 98 and below)
