MSP file size - increase by two times
K
Kenny Kek 👤 Member for 16 years 6 months
Alexandre Faulx-Briole 👤 Member for 23 years 6 months
Hello all,
it is generally not good practice to use MS Project 2007 / 2010 before the 1st service pack is released; the original released is packed with a large number of bugs
Alexandre
W
Willem Prinsloo 👤 Member for 17 years
I seem to sit with the same problem. My project is 6000 lines and I can not open it anymore. I tried a powerful PC assembled for drawings but it still doesn’t work. Please assit if possible. Any suggestions PLEASE?
Don’t give up if you and Alexandre still want to work it out. Maybe Alexandre will be able to give you some hints you will thereafter use to your benefit. Comunicate with him via PP mail if you wish to see if it makes any sense.
IZARC and rar files are needed when transferring many files as rapidshare can only upload files one by one. You can upload the 100MB MS Project file without converting it to a rar file. Downloading is free.
Good luck
K
Thanks Alex / Rafeal,
I think I would just live with it.
My email not able to send such big size file.
note: The 100mb is the xml file.
Can you e-mail the 100MB file Kenny got after the explosion? Is just a 600 activities job.
What is the average e-mail size limit in the E.U. ?
You can consider rapidshare to transfer files of more than 10MB if this is still the limit on e-mails. Rapidshare has a premium account that if used wiselly can be enough. You can use IZARC a free utility to convert several files into a rar file with a 200MB limit. Not sure about it being able to split a single larger than 200MB file into several 200MB files, this might be a limiting factor if MS Project tends to create files larger than 200MB for your files.
Darren Kosa 👤 Member for 18 years 5 months
Hi Kenny,
Re-save the file, but use a different title.
E.g. File > Save As > Project1.1, instead of File > Save Project1
Does this have any effect?
I’ve found in the past that if I just click the ’Save’ icon to overwrite the file then it is very susceptible to file bloat. I now always use the File menu to ’Save As’ even if I’m saving it as the same file name.
Darren
EDIT: I should add that I don’t have any external links in my files
Kenny,
Could you send me your file? Before and after the size explosion? I’ll give you my email via Private Message
Alexandre
K
Thanks Gentlemen,
Try out the suggestion, but seem like not effective.
Also, try the http://project.mvps.org/faqs.htm #43, can only save as xml file (mpd option not available).
The file size increased to close to 100mb in xml format, can you believe it? Can’t even open it (maybe my machine not powerful enough)
Still no solution
Mike,
MS Project does not have a limited file size; at least if you do not still use MSP98!
What I answered Kenny is that every view, filter, ... you are using while working on a specific schedule will add bytes to the file size; and sometimes megabytes rather than small bytes
Alexandre
M
Hi Kenny
I did not know that MSP had a limited file size.
Another good reason for staying away.
Kenny,
MSP saves in the project files all the views, tables, filters, vb modules (macros), calendars, ... being used in a specific project.
Go to Tools, Organize, and look at what items you could delete from the file.
Alexandre
K
Opps ! Forgot to mention.
The total number of activities less than 600 items.
Thanks!
Alan Dunn 👤 Member for 16 years 7 months
I used to have the same problem (with Office 2007). I updated a service pack (1 i think) and the problem went away. Before that I had to save as XML and then save as a new mpp every few weeks. So now I have the Service pack, the program files still get corrupted sometimes forcing me to abandon my current version every so often.
I’ve had occasions where the whole structure has become jumbled, summary tasks becoming tasks and vice versa, the programme complaining of a loop including a task that doesn’t exist etc. etc. Todays one was more subtle. All activities were in their place but the float calculations were wrong. Some activities having float as if they had no successor, however they did. Bottom line, I only use this software if a client INSISTS on it.
Featured Partner
Rajkamal Tangirala
Rahul Kumar
blake333_
Jeamiell Ostrovsky
Hamzah Ahmed
Quinton van Eeden
Sunchana Johnston
Akram Hammam Mohamed
Sagar Raut
Patricio_aoa
