Relationship lines & critical path
RichTea66
Muneer Muhammad
Manny Onifade
Hunais M J
Soheil Barekat
henrigpc
Hashil Ali
Nigel Hussey
Dear all,
obviously, you will read:
"the relationship lines have the color of the predecessor bar"!
Alexandre
If instead of using WBS you can live with the use of Flags then follow the links and download the PDF and MS Project file, you should be able to figure it out. Maybe even better this will give you a clue.
For color coded bars:
http://rapidshare.com/files/236514057/Color_Coded_CP.pdf
http://rapidshare.com/files/236513993/Color_Coded_CP.mpp
Download revised files for color coded Bars and Relationship Lines, remember also shapes can be customized.
http://rapidshare.com/files/236543100/Color_Coded_CP.pdf
http://rapidshare.com/files/236543326/Color_Coded_CP.mpp
By trial and error you should get to where you want or close, within the limit as described by Alexandre "the relationship lines have the color or the predecessor bar".
mukunda,
the relationship lines have the color or the predecessor bar; if you want a line to be yellow, just use the yellow color for this specific predecessor
MSP lets you show either ONE critical path only or MULTIPLE critical paths in the same project: Tools, Options, Calculation; it is also possible to change the float minimum value below which a task in critical (same place).
Or you could write a formula (Tools, Customize, Fields) to calculate a critical path of your own
Alexandre
