Planned % complete column
S
Se de Leon 👤 Member for 25 years 1 month
As long as you have a proper CPM in your schedule, you can always calculate delays in MPP.
Step 1: Update completely and accurately your project
Step 2: Use Tools Tracking Update Project, then click Reschedule uncompleted work to start, then assign a date.
Step 3: Review your updated Critical Path
Step 4: if you can do it, mitigate delays, if not, voila, you have your updated completion date.
I hope this helps.
S
There’s another way to do this.
Saving a separate file of your baseline project, and name it as "as planned" file. Use the Tools Tracking as complete through, then assign a date. After MPP calculates the % complete, copy paste this field to your baseline or current project as a text field. This is similar to P3, the only difference is you have to cut and paste the calculated as planned %, not assign the "as planned" schedule as a target schedule.
what darren has explained is perfect if you really want a dynamic way of showing the as planned %. If you have not get the hung of the complicated formula, you may use the above as an alternative way to show as planned %.
Darren Kosa 👤 Member for 18 years 5 months
Chris,
Whichever field you’ve used to show Planned % Complete, should also have ‘calculation for task and group summary rows’ options. Check the ‘use formula’ radio button and it should then roll up to summary levels.
(Tools > Customize > Fields)
Darren
C
Christopher Paulraj 👤 Member for 17 years 4 months
Thanks Darren,
The formual perfectly works, but it doesn’t calaculate for summary bars. is there any solutions to calculate the baseline % complete for summary bars?
Rgds
Chris
Siddharth Ranadive
Aidar Kurmantayev
Dave Morgan
blake333_
Mohammed Netarwala
Moahmed
S Z
Iftikhar Awan P.Eng.
ahmad rashidi
paulciszewski
