Closing open ends in MS Project and FS-links with negat
B
Bo Johnsen 👤 Member for 20 years 4 months
Ray Messinger 👤 Member for 25 years 3 months
Here a a macro that will link two selected tasks S2S and F2F by adding a Finish milestone between them. It will add the S2S lag if they are overlapped.
Sub LinkS2SF2F()
’**********************************8
’* This macro will connect selected tasks with Start-to-Start & F2F ties
’* Ray Messinger 8-Aug-08
Dim tt As Task
Dim tt1 As Task
Dim tt2 As Task
Dim myProj As Project
minperday = ActiveProject.HoursPerDay * 60
Set myProj = ActiveProject
Set myTasks = ActiveSelection.Tasks
fName = ActiveProject.name
If myTasks.Count <> 2 Then
MsgBox "You must have two tasks selected for this macro to work"
Exit Sub
End If
Dim TaskIDs(2)
For Each tt In myTasks
tcnt = tcnt + 1
TaskIDs(tcnt) = tt.ID
Next
’--- Add Start to Start ---
For t = 1 To tcnt - 1
Set tt1 = myProj.Tasks(TaskIDs(t))
Set tt2 = myProj.Tasks(TaskIDs(t + 1))
Sdate1 = tt1.Start
Sdate2 = tt2.Start
DDiff = Application.DateDifference(Sdate1, Sdate2)
dlagday = Int(DDiff / minperday)
dlagday = dlagday & "d"
tt2.TaskDependencies.Add tt1, pjStartToStart, dlagday ’add predecessor to task2
tt2.ConstraintType = pjASAP
Next
’-- Add Finish Milestone ----
tid = tt1.ID
NewID = tid + 1
ActiveProject.Tasks.Add name:="The New Task", Before:=NewID ’insert after
Set NewTask = myProj.Tasks(NewID)
With NewTask
.name = tt1.name & " Finish"
.Calendar = tCalName
.Duration = 0
End With
NewTask.TaskDependencies.Add tt1, pjFinishToStart, 0
tt2.TaskDependencies.Add NewTask, pjFinishToFinish, 0
Beep
End Sub
T
Trevor Rabey 👤 Member for 20 years 7 months
Your option 2) is best, regardless of the downside considerations that you mention, which I think are not very significant.
Options 1) and 4) are the worst.
I don’t understand option 3).
I notice that you favour option 4) without mentioning the arguments against it.
Before software, project planning was possible.
Then early software made critical path method networking possible even though functionality was limited to FS links with positive or zero lag only.
It is still possible, and recommended good practice, to use only FS links with positive or zero lag.
Start with some rules and stick to them, and don’t just bend or break them for convenience.
Every Task should have at least one FS predecessor and one FS Successor.
When it seems necessary to use other kinds of links and negative lag, it is really a sure indicator that the Tasks need to be chopped up into smaller pieces.
Lots of Milestones can be very useful as predecessors or successors for Tasks which don’t appear otherwise to have one.
Other links can be applied, as extras, after every Task gets at least one FS predecessor and one FS Successor.
FS links are a good representation of reality. Every Task cannot start until some other Task is finished.
FS with negative lag is a joke, and evil as can be. The signal for the start of a Task B goes off in the future and it is impossible to know when to start Task B, ie when you are x Days before the finish of Task A. It is like jumping off the starting blocks at the swimming pool 0.5 seconds before the gun goes off.
Featured Partner
xerxes
edwin
jhalluk69
wilmoahyi
Peter Holroyd
Robert Guers
Jerry Robinson
Elyar Safarov
Christopher Ganotice
Our Partners
