Resource Pool
Emmanuel Valentine
User offline. Last seen 11 years 24 weeks ago. Offline
Hi Guys
I have created a resource pool to be used by 5 different projects for but with additional fields for departments, teams, line managers etc which are not standard on MSP. Every time I copy the pool to another worksheet or share the resource pool with any of the projects. it only copies the MSP standard field such as names, groups, types etc.
How do I get all the fields on the resource pool to copy to all the other projects?
EV
Trevor Rabey
User offline. Last seen 1 year 38 weeks ago. Offline
This is not a "conflict message", just a standard warning.
The Text2 field that you are bringing into the file has a restricted data value list and if the file you are bringing it into has the same field with data in it then that data will be lost.
Surely all the rest worked fine?
Emmanuel Valentine
Hi Trevor
I tried it but it is not working, there was a conflict message "The value list data entry option is set to restrict the field to only those items in the list. This may invalidate some existing data in the "text2" field.
Am I doing it wrong.
EV
Trevor Rabey
Easy.
Open the Resource Pool MSP file.
Open the MSP project file that will use the Resources from the Pool.
Use Tools, Organiser to select the Fields tab, and select for Resources rather than Tasks, and drop down the file list to select the Resource Pool file (which will be there if the file is open).
Then just copy the custom fields into the project file.
Repeat similar for other files.
