Ms Project and Baselines
P
Philip Jonker 👤 Member for 21 years 7 months
hI SHEILA,
Do not worry that much about it, just give them a swift kick under the rectum, and they will reply.
Philip
Alexandre Faulx-Briole 👤 Member for 23 years 5 months
Sheila,
1. Go to Format, Bar Styles; then add a bar that represents "Normal" tasks, begins with "Baseline 1 Start" and ends with "Baseline 1 Finish"; do the same for any other baseline you want to display on screen
2. To save "Baseline x" as "Baseline y", go to Tools, Tracking, Save (original) baseline, then select Save interim plan and copy "Baseline x" to "Baseline y".
Hope it helps,
Alexandre
P
Hi Sheila,
The questions is simple, however as I am not a full time MSP user the answers are noet coming of the tp of my head, but there is always work arounds to keep this type of information. make sure you save every file/version with its baseline when it is set, and under a different name. at least this keeps the history, as MSP does not have unique ID’s at least you can go back and find the info at a later stage, itis cumbersom, but at least you are not losing info.
Philip
Soheil Barekat
Luis Jr Ngade
Ben Welsher
Rohan Dashputre
AMECHI ANAKWENZE
Jayaprakash Sekar
arash.karmand
Vahidazimi01
David Smith
