Should splitting tasks increase duration ?
J
James Griffiths 👤 Member for 20 years 1 month
Hi Vinod,
Glad you "fixed" the problem he he he.
The term "Fixed Duration" should be more accurately interpreted as "elapsed duration" - as it spans the entire length of the activity, from start to finish - regardless of any idle-time or task splits. In general, however, he task-types are important when you are applying resources to the activities. A so-called fixed duration task will retain its end-date, even if you work fewer or more hours than planned. It will adjust the remaining hours to spread equally across the remaining duration. In essence, you are correct in that a fixed-duration task assumes no idle time unless you specifically input a split. Once you input a split, you might as well allocate it a fixed-work or fixed- unit attribute.
The fixed-unit and fixed-work task types have different behavioural characteristics when applying resources and re-scheduling uncompleted work - and knowledge is best gained by doing a few experiments. SO I’ll let you get on with it, as it is virtually impossible to explain it in words.
Cheers.
James.
V
vinod raturi 👤 Member for 19 years 10 months
Hi James ,
Your presumption about task set at "fixed duration" was correct.
But what does this behaviour implies , does it mean if i have task whose duration is fixed , i cannot have idle time for that task . Since splitting will negate the definition of task " Duration " ?
Or is there some other angle to it ?
thanks,
regards,
vinod
J
Hi Vinod,
Your task-type is probably set at "Fixed Duration". Double-click on the task, click "Advanced" tab, change the task-type to either "Fixed Work" or "Fixed Units". This will then display the duration in accordance with how many "activity days". Note, however, that all summary-task durations are set at Fixed Duration, so you cannot change those.
HTH
James.
T
Trevor Rabey 👤 Member for 20 years 6 months
When I try what you are doing, my original duration is preserved, regardless of how many times I split the Task, down to 5 x 1 day splits with one day spaces.
Your definition, using "active" days is pretty close.
Splits are pretty much the only exception to the definition of duration as:
the number of working days, according to the calendar for that task, from the start of the task to the finish of the task.
Check your calendar for the task.
Vahidazimi01
David Smith
Peter Holroyd
fridau
Rahmat Hidayat
pinoyplanner
Saqib Ullah
Luyanda Ndlumbini
Jeff Waldrop
