Rollup Customized Columns
Valerio Giancaspro
User offline. Last seen 4 years 28 weeks ago. Offline
I’m trying to rollup the values of customized fields. I’m using numbers and formulas. I’ve applyed "sum" to the rollup value. I’ve noticed that if I use formulas to customize the number fields the rollup value (sum) does not display always the correct vaule. It’s like it doesn’t refresh the calculation. I’m using Project 2003 (SP1). Any suggestions?
Will Russell
User offline. Last seen 11 years 43 weeks ago. Offline
Which fields/values are you trying to customise? If it is to do with any of the baseline fields then the values will only be calculated at the time you save the baseline, not before.
Will
