Saving Layouts
P
Paul Harris 👤 Member for 25 years 3 months
I suggest you create a View, Table and Filter (if required) all with the same name and use them together and adjust them in the same way as one would adjust a Layout in P3.
Unfortunately MSP does not give you the option of saving changes to a View in the same way as P3 so any change to a View is written to the database as soon as it is made. You will find this very frustrating, like many other things in MSP after coming from P3.
Paul E Harris
www.eh.com.au
Raj Maurya 👤 Member for 22 years
Philip,
you can use different views to costomise the layout(As in P3. Follow Daya’s suggestion to create views as per your need.
T
Tony McClennon 👤 Member for 23 years 8 months
Hi Phillip,
Ref your problem with tasks being linked automatically, use
Tools->Options->Schedule(Tab), then ensure that the option titled "Autolink inserted or moved tasks" is unchecked. This can then be set as your default.
Tony
Dayanidhi Dhandapany 👤 Member for 23 years 4 months
Hello Philip,
I hope the following may help you:
1. Click View->More Views->New View or copy existing layout view and do some modifications to suit to your requirements.
2. Tools->Options->Calculation(Tab)->Set calculation mode to Manual(instead of Automatic)
Cheers!!!
Daya
Featured Partner
Patricio_aoa
jeoffrey reyes
Zine Eddine
mxsiegel
Mattvtek
Gareth Evans
PP Admin
Rajkamal Tangirala
Rahul Kumar
