Can you copy views from one programme to another.
Sam Wiggins
User offline. Last seen 13 years 30 weeks ago. Offline
I am trying to copy a view from one programme that I have spent a fair bit of time setting up to a number of other programmes for projects that are allready underway. Is there an easy way to do this or do i hve to go through the long process of reformatting the view in each one.
Thanks in advance
Sam
Anthony Mocke
User offline. Last seen 10 years 20 weeks ago. Offline
Found this part of copying & pasting very useful & time saving...
Anthony Mocke
robmx 1
User offline. Last seen 4 years 13 weeks ago. Offline
Hmmm... just had a look in Asta, you can definately copy across the library items for filters and sorts but i cannot see a way of copying an entire view across. Perhaps you could create a template out of the programme containing the view you want for use in the future but that doesn't much help with a programme which is already in existence.
Jonathan Dann
User offline. Last seen 11 years 46 weeks ago. Offline
Have you tried opening the programme you want to copy from and the one you want to copy to? Make sure the LIBRARY view is open on both programmes then left click and drag from the programme it is in to the LIBRARY view of the other programmes. You may be able to right click, copy and paste.
Jonathan
