The pros and cons to export file from mp to pp8.
Paola Veas
User offline. Last seen 14 years 15 weeks ago. Offline
Hi all,
Is it really reliable to export file from mp to asta project?
I have set up both programmes with the same characteristics, like weather and standar calendars, durations, etc.
Once I have exported a file from mp to pp, Can I assume the files are exactly the same or I should do a few changes to fix some lost information?
Paola Veas
Assistant Planning Engineer
New Zealand - Chile
Daya Sugunasingha
User offline. Last seen 17 years 18 weeks ago. Offline
You always have to check each item/task against the original after converting to ensure that it is correct.
Do not just export and hope for the best or trouble awaits you.
DS
