Cigarette butt
9 replies [Last post]
User offline. Last seen 1 week 3 days ago. Offline
You have 16 non filter cigarettes on your pocket. In those hard days you decide to smoke the cigarette butts for some saving. If with 4 cigarette butts you can make a new cigarette and smoke it how much you will smoke?
This is a question for those of us who had to earn everything the hard way, nothing to waste, you got to smoke the last butt even if you burn your fingers.
Carlos Arana
User offline. Last seen 6 years 11 weeks ago. Offline
Actually, you get to smoke 21 times, as Mike said, but the most tobacco you will be consuming by doing this trick is the tobacco contained in 15.75 cigarettes.
Carlos Arana
The correct answer is 15.75 cigaretes. If you weren’t saving butts, you’d smoke only 12 cigarettes.
Mike you got it right, you could not forget the last butt, this was key. Are you using tweezers or nails for the last butt?
User offline. Last seen 35 weeks 4 days ago. Offline
Hi Rafael
16 cigarettes will furning 16 butts
16 buts make 4 cigarettes
4 cigarettes make 4 more butts
so 21 cigarettes from 16 plus 1 butt.
Mike T.
Is compatible with both. You can use mathematica to get the solution but not needed.
Lawrence Cuozzo
User offline. Last seen 12 years 18 weeks ago. Offline
My answer depends on whether I use P6 or Spider to figure out the problem.
If you smoke them all till the end using hair pulling tweezers then there will be no butts. If smoking with bare hands they will have, unless very experinced with your nails.
There is no catch, is a mathematical problem, a resource usage issue.
Carlos Arana
Do non filter cigarettes have butts?
