Rubbish Piping Standards
direct quote from a Client's Piping Specification
"The inside diameter of the pipe should be less than the outside diameter to prevent the hole being on the outside",
Don't get me started on their definition and identification of a "long pipe"
B
Bhavinbhai Lakhani 👤 Member for 2 years
Hello Peter,
It's actually the opposite! The inside diameter of the pipe should be larger than the outside diameter to ensure the hole or opening is on the inside. This is because the inside diameter refers to the diameter of the inner opening of the pipe, while the outside diameter is the diameter across the widest part of the pipe, including its walls. Having the inside diameter larger ensures that any opening or hole is contained within the pipe, not on its outer surface.
Hope it would help ypu.
Thnaks,
Arshman
Stan Remiszewski
GeoVe
JAGAN REDDY MUSUKU
Nick Johnson-Pond
sairedz25
Ahmed Awad
Syed Shoeb
Vimukthi
bal aji
