Data Exchange between TILOS 9.0 & MSP 2013
V
Vignesh S 👤 Member for 11 years 2 months
Could any one guide me on how to exchange data between TILOS 9.0(rather TILOS) and MSP2013
V
I am getting the below error while importing TILOS9.0 exported data in MSP 2013.[[wysiwyg_imageupload:2691:]]
Anybody have idea on how to overcome the above error.
Alexandre Faulx-Briole 👤 Member for 23 years 6 months
Vignesh,
the Tilos exchange module between Tilos and MSP or Primavera is included free of charge with the demo version of Tilos; otherwise, you have to purchase it separately.
To create an import/export profile:
Click New, then Edit, check the Library Data items you want to select fields in for export, then click the red check-mark on the right side of the combo box, and select the fields you want to be exported
Click OK twice when you are finished, give the profile a name; possibly save the profile if you want to use it with other projects, as by default the profile will only be available in this particular project
Click Finish to export.
Hope this helps,
Alexandre
V
Alexandre,
Thanks for your response. But, I need detailed steps as I'm facing issues with profile creation etc., Also, I am not getting the TILOS exchange macro in MSP2013 as we get in MSP2010.
Vignesh
Vignesh,
Go to File, Export; then select the second option: XML
Define the destination file, or click Clipboard; the select the xml file containing the export scenario, i.e. the files you want to export.
Alexandre
Featured Partner
Zine Eddine
mxsiegel
Mattvtek
Gareth Evans
PP Admin
Rajkamal Tangirala
Rahul Kumar
blake333_
Jeamiell Ostrovsky
