How to Delete Links Using Excel?
Trevor R Bird
User offline. Last seen 11 years 42 weeks ago. Offline
I have a pipeline project that has reversed direction - see my previous post. I’ve been able to resolve the issue of reversing the start & end chainages and dates for each activity using Excel, and I can add reversed links to Tilos using Excel. However, I have not found a way to delete existing F-S links in Tilos using Excel so they can be replaced by necessary new F-S links. If I do add my new F-S links to the reversed activities circular links are created:(
Any clues on how to delete links using Excel?
TRB
Hubert Geier
User offline. Last seen 8 years 21 weeks ago. Offline
Groups: TILOS
Trevor, the problem is that links have no ID’ s and there can be multiple between 2 tasks.
If you import all links using Excel or ASC link, why not delete all before import using the task link list.
I will check if there is a work around.
venkatesh K
User offline. Last seen 7 years 50 weeks ago. Offline
Hi TRB,
You can use the Successor Relationship Export option from Primavera to Excel and then u delete the activity and import again. hoping it will work.
Venkat
