Planner as a Career
6 replies [Last post]
Nithin Raju
User offline. Last seen 6 years 33 weeks ago. Offline
I joined as a planner with a small contractor (under 125 workers) working in the oil and gas industry. I am based in Singapore and my company is involved in pipeline and structural works within a refinery & a chemical plant. To elaborate a little more about me, I hold a masters degree in mechanical and manufacturing engineering from the UK. My question is how do I plan a career in planning?. I have a basic understanding of Primavera. I am also now able to break down the project scope (usually pipeline construction) into meaningful steps (WBS). Create a logical work sequence etc. I would like to know about any specific add on courses that I can take up to enhance my knowledge an advance myself as a planner. As the exposure I am getting from this company I currently work is very limited I would like to move onto a bigger company some time later, for that what are the skills I should be learning?. Would a short course on Project cost estimation be a nice choice?. Kindly help provide some answers for this confused beginner.
Nithin
abrugar jons
User offline. Last seen 8 years 13 weeks ago. Offline
Thank you Patrick & Stephen for those valuable advice. As Patrick suggested, I'll try to obtain one of the certifications to widen my knowledge. I am thinking of staying with my current employer for another year and then make a move.
Best Regards
aurugar
Nithin Raju
Stephen Devaux
User offline. Last seen 24 weeks 3 days ago. Offline
Hi, Nithin.
You received some excellent advice from Mike and Patrick. I also am a big believer in the importance of planners/schedulers understanding the business basis for a project. I believe that this will become a major trend in the next few years.
I would suggest you read this 2012 article titled "The Drag Efficient: The Missing Quantification of Time on the Critical Path" in Defense AT&L Magazine (it is a PDF file). (BTW, this article was reprinted as a chapter in this 2013 oil & gas project management book.
If you find the concepts interesting, I would urge you to read my 2014 book Managing Projects as Investments: Earned Value to Business Value. It will offer a different way of viewing projects, and different (i.e., economics-based) skills that could set you apart from others.
Steve the Bajan
Patrick Weaver
User offline. Last seen 1 week 5 days ago. Offline
Hi Nithin ,
The roles, responsibilities and capabilities of a good planner are diverse, but as Mike said, being able to use software is a minimal need.  To understand the full spectrum see: http://www.mosaicprojects.com.au/PDF/Attributes_of_a_Scheduler.pdf
The emerging aspect is certification / qualification.  The Guild hosted on this website is the most comprehensive.  Straight certifications are available from PMI and AACEi, see: http://www.mosaicprojects.com.au/Planning.html#Certifications  You will find studying for any of these certifications will push your formal knowledge significantly.
Pat.
Nithin Raju
Mike,
Thank you for your reply. I myself had this feeling that I am just a scheduler as of now!. Still I can tell you that I understand the whole construction process in my niche area because I am at the field for at least two full days a week, more if the team is involved in any critical tasks. The thing is being a foreigner here in Singapore, none of the companies may offer a trainee position to foriegner they'd rather go for a local. That is why I asked about any add on courses that I should be doing to get an edge over others. Once again, thank you very much for your reply.
Nithin
User offline. Last seen 22 weeks 17 hours ago. Offline
Hi Nithin
Currently you are working your way to becoming a skilled scheduler in a niche industry in the oil and gas field.
A scheduler is not a planner.
The best qualification for a planner is to gain a full understanding of the construction process and experience in your specialist industry - skill with the software is secondary.
My advice therefore is get a job as a trainee scheduler with a main Oil and Gas installer and stay with it for at least 5 years.
Ask questions and learn all the time.
