UAE market for Planners
12 replies [Last post]
J Venkatesh PMP P...
User offline. Last seen 11 years 41 weeks ago. Offline
Groups: GPC Qatar
Heyyy...
can anyone post me what s the present market salary one Planner can get in UAE
for 9years exp. guy (8yrs in India + 1 yr in GCC)
UAE planners, awaiting for ur replies
venkat
vikas agrawal
User offline. Last seen 5 years 30 weeks ago. Offline
Raviraj,
You mentioned NICMAR is valued much in gulf. How about the MBEM from SPA New Delhi. Any Idea? mikki123 at the rate gmail.com
vikas agrawal
A D
User offline. Last seen 4 years 14 weeks ago. Offline
Hi Dave,
If u see d last line, it means there is no racial discrimination in the society as such, yaa but as far as salaries are concerned, difference is too high and vary greatly from country u belong.
It really doesn’t matter, how hard u work or u have all the technical skills, u may b paid better than ur nationals but still the gap will be huge to cover up ur own rights.
and the funny thing is THERE IS DISCRIMINATION IN THE SALARY, but not in the living cost. :-(
Raviraj
ashraf alawady
User offline. Last seen 10 years 20 weeks ago. Offline
In all the cases ,the personality will be the leader .
wehave to insist and work hardly to get our full rights.
ashraf alawady
my the nationality will effect on the expected salaries but for profissional and experianced pepoles i believe it will have no major bad effects.
You have to insist to get your full rights.
A D
Also, depends what kind of experience u r having...
5 years in primavera is too good with at least 2 projects completed..
Package is worth to be asked for!!
It also depends from which country u r belonging... (No Racial Discrimination, but its a fact in Dubai. Salaries depends upon country from which u belong)
Dev Tamboli
User offline. Last seen 11 years 25 weeks ago. Offline
hi guys,
anyway it depends on the organisaion or sector in which you are working,
like if you work for client or consultants you get higher slary.
even in the construction sector it varies between building and infrastructures.
but as per current scenario for 5+ experience with PG qualification as ravi said (preferably from NICMAR) you can get 15000 easily.
cheers,
ashraf alawady
For 5 years exp. salary will never jumb over 12000DHS
A D
A lot depends on whats ur basic qualification. Will get better salaries, if u have done PG (Preferably from NICMAR - Valued very much in UAE)
As jaya said, if exp is 9 years, then definitely he can have a minimum of 22/24 thsnd dhms.
For 5 years, defin, around with four years out of India exp., u can have 15000 Dhms salary (In Abu Dhabi/Sharjah/Dubai/Ajman)
Pranab Kumar Deb
User offline. Last seen 3 years 37 weeks ago. Offline
Hello Raviraj ,
What about a planner with 5 yrs exp = 1 ( India) + 2 ( UAE)+ 2 ( CIS)
regards
deb
A D
Working as Sr. Planning Engr. you can get more - A minimum of 15000 Dhms.
ashraf alawady
10,000Dhs to 15,000 Dhs based on the profissionality and other skills.
Karim Mounir
User offline. Last seen 10 years 28 weeks ago. Offline
