Scope Management
moutaz aldeib
User offline. Last seen 4 years 1 week ago. Offline
Hi all,
in order to define scope of the project, we need to define the requirements and it might be all the requirements are in the sope or we might identify some of the requirements to be included in the scope. Two questions i have:
1- what is the best tool to collect the requirements? i heard about "Requirements Traceability Matrix RTM" and if any one have a real example about it.
2- why we explled some requiremnets though we collect them in th efirst stage?
best,
muataz
Patrick Weaver
User offline. Last seen 1 day 7 hours ago. Offline
User offline. Last seen 17 weeks 4 days ago. Offline
glad i could help
moutaz aldeib
Thanks Zoltan
every type of work is different so depending on your type of work you will have minmum requirements that are on evry project that you do. You use this minimum requirement matrix as the baisis for starting and then add the project specifics to it based on that particular project.
if is it electrical design and cosntruction you will always have power load calculation requirments, lighting calculations, single line drawings, switch gear submittals etc.
