Slippage Calculation using Total Float
J
Jeff Limpin 👤 Member for 18 years 9 months
Ashok Kamath 👤 Member for 18 years 8 months
Can you not establish your Target Project in the Project Overview dialog box (Targets tab)and have a column in your graphical view that shows Variance Target - Early Finish
Have your Baseline schedule as the first Target Variance column to compare with current.
This should show you a running tally for slippage.
Ashraf Jahangeer 👤 Member for 19 years 2 months
Hi There,
The question is how to copy?
Global change is not possible.
Ashraf
S
Scott Sando 👤 Member for 18 years 9 months
How about:
Copy the target float figures into a custom field, then create a second custom field subtracting current float from the figure in the first custom field?
L
Larry Rino 👤 Member for 18 years 8 months
Is it really necessary to show the difference (current total float minus the target total float) in P3, if not I suggest to export your P3 data in Ms Excel and put formula in the difference column (present it in Ms Excel).
I hope these helps.
I broke my head over it but could not do it through global change.
There is a more crude method of exporting the Target Float and Current Float and importing the difference in a Cutom data column.
Ashraf
Mohammed Netarwala
Moahmed
S Z
Iftikhar Awan P.Eng.
ahmad rashidi
paulciszewski
Catalin Suditu
Laraib Fatima
Adrian Fletcher
GeoVe
