Metal construction
Abhijit Kale
User offline. Last seen 6 years 11 weeks ago. Offline
Dear Friends,
Can any body help me out with some leterature related to the "Metal Construction": (Steel structures) for Industrial structure.
Possibly give Literature related to procedure, process, type of joints and quality checks required for Metal construction.
I m new person in the field of metal construction and so far i was the part of large infrastructure projects.
Expecting the +ve feedbacks
A D
User offline. Last seen 4 years 2 weeks ago. Offline
I hav written that manual in 2005, so i know there’s everything in that, what u r searching for (For Pre-Engineered Buildings)
In which comapny u r working now? I may help u little bit more.
Rav
Abhijit Kale
Thank you very much.
Ill check out the manual of tata bluescope steel.
Thanks and revert back to you
cheers
Abhi
A D
Hi Abhi,
I have worked previously with Pre-Engineered Building (PEB) firms. Its all site-bolted connections with all welding for built-up structures completed in factory itself and then transported to site. If u r in India, u can check Installation Manual of TATA BlueScope Steel. That will give u an idea of entire process of construction of Pre-Engineered buildings, right from Unloading to final handing-over of steel buildings including quality checks.
U can check the website of zamil steel for literature. Or if u want some specific information plz send me PM, i will revert back.
Rav
