Fill down
samey uddin
User offline. Last seen 10 years 3 weeks ago. Offline
hii i want to know for waht purpose  does the option "filldown" is used for ,it will be better if someone can explain with an example ..
thanks
samey uddin
thanx ..
xadlim B.
User offline. Last seen 11 years 42 weeks ago. Offline
you can use also short cut for fill down CTRL+E
Hope it helps......
David Craig
User offline. Last seen 1 year 28 weeks ago. Offline
Hi Samey,
This option is used to duplicate other cells within your programme. It is pretty similar to Microsoft Excel. If you want to populate several activities with a different calendar for example, you would make sure the little highlight box was in the calendar you wanted to copy down, select the activites to change or add calendar to by using either Shift or Control, then right click on the mouse and select fill down. This will copy the calendar to all selected activities.
I hope this helps!
David Craig
