Turn off the annoying BEEP sound
Kevin Button
User offline. Last seen 3 years 43 weeks ago. Offline
The projects I work with have been migrated to a different database and now every time I make a change and press the Enter key, I hear a beep which becomes annoying after a while. How can I turn this off?
Switching off the sound on the PC and/or plugging in headphones does not solve the problem, the beep continues. I know that instead of pressing Enter I could click the mouse somewhere else on the screen and I will not hear the beep, but I try to avoid the mouse as much as possible as it slows me down.
I'm using P6 7.0 SP2 on Citrix. Any help would be appreciated.
Kevin Button
Thanks Rafael for your replies, I will forward the Citrix fix to our Primavera Admin.
The reason I know it's not a problem with my laptop is because I use 2 separate P6 databases, both of which are on Citrix, and only one of these causes the beep while the other does not.
User offline. Last seen 11 weeks 3 days ago. Offline
Maybe you are shutting down the volume of the virtual machine and not the volume of your physical machine. If you cannot see the volume control of your virtual machine on the screen within a window on your screen try running the virtual machine at not full screen mode, maybe the ESC key will toggle you out of full screen view. Another one try using the volume controls dedicated buttons on your machine if a laptop.
Good luck.
The issue might be with Citrix.
http://support.citrix.com/article/CTX126856
Also look on the above post for other temporary alternatives until you solve the issue.
Kevin Button
I just had a thought - this might be a setting in the PM.INI file. Would somebody with a local P6 install mind checking for me?
