Screening Questions for P6 Candidates
7 replies [Last post]
David Millheim
User offline. Last seen 14 years 7 weeks ago. Offline
I need to prescreen candidates for a Scheduling position requiring solid P6 skills, prior to sending them on to the hiring manager. I've never used Primavera myself. Can you share with me a few basic questions to determine if a candidate really knows how to use Primavera P6?
User offline. Last seen 21 weeks 4 days ago. Offline
You can ask. How many BUGS have you identified in P6.
If the answer is less than a trillion then he/she have not experienced P6 in depth.
Raj Radhakrishnan
User offline. Last seen 13 years 15 weeks ago. Offline
Mike - actually u can change the color of an individual task bar.
Steps: Add New Bar, Select Color, Select Filter, Add New Filter (Set Criteria - i.e. Act ID - XXXXX, or WBS equals XXXX), and select the criteria = current (or late, or critical etc.) and view layout.  For example, if you set the filter to have all the design activities to a particular color, it wll show up in a different color.  I use it for presentation purposes all the time - Engg in one color, Procurement in one color and Construction in another color.
mukunda y
User offline. Last seen 11 years 44 weeks ago. Offline
difference between the Scheduled % Complete, duration % complete, Unit % Complete, Activity % Complete.
Mukunda
Sapna Rani
User offline. Last seen 13 years 43 weeks ago. Offline
Hi david,
You may ask questions like:-
1.Can you have more than1 critical path in P-6?
Ans-Yes
2.What is schedule tracker in P-6?
Gary Whitehead
User offline. Last seen 6 years 6 weeks ago. Offline
Hi David,
Having not used P6 yourself makes this a bit tricky, as there's not many questions I can think of that wouldn't have more than one "correct" answer, and you'd need to know the topic to be able to interpret the answers.
The below might do you though:
Q: What is the difference between retained logic and progress overide?
A: When you choose Retained Logic, the remaining duration of a progressed activity is not scheduled until all predecessors are complete. When you choose Progress Override, network logic is ignored and the activity can progress without delay.
Q: What does progress spotlight do?
A: The Progress Spotlight feature highlights the activities that should have started or finished during a specified timeperiod
Q: What is the difference between  the "assign baselines" and "maintain baselines" dialogue boxes?
A: Use the "Maintain Baselines" dialog box to create, delete, or restore baselines for the project. Use the "Assign Baselines" dialog to assign project, primary, secondary, and tertiary baselines to a project, from the available baselines created through the "Maintain Baselines" dialog box.
(All answers cut & pasted from the Primavera help file)
User offline. Last seen 33 weeks 3 days ago. Offline
Hi David
You might like to start with the things that P6 can't do:
Change the colour of an individual task bar.
Underline the text in a single column cell.
Copy and paste directly from excell into the columns.
Arun sangwan
User offline. Last seen 13 years 12 weeks ago. Offline
question which u need to ask can be in how many ways a schedule can be prepared?
