Using SDK requires superuser privilages ?
Roozbeh Taheri
User offline. Last seen 8 years 26 weeks ago. Offline
In order to edit or add / write data into P6, is superuser privilages is required? If that is through then not so many people can use it. There are no much advantage in being able to read the information. SDK would be useful if it could be used to update information such as activity codes values (dictionaries), which can not be done through import from excel.
