How to create a 2wk look ahead schedule in P6
11 replies [Last post]
L P6
User offline. Last seen 3 years 41 weeks ago. Offline
Hi all,
I am still finding my way around P6 and would like to know if anyone can giuve me a step by step outline of how to create a a 2wk look ahead filter. I am familair with creating filters but have never done one for a look ahead.My two main questions are:
  1. Do I use the "Earliest start date"  and "Latest finish dates" instead of "Start" and "Fininsh"?
  2. I aslo want to include all work that is still in progress during the lookahead period regardless of when it starts or will finsh. Is this good practice to include this criteria as part of a look ahead schedule and if yes, how would I do that in combination with the dates filter in question 1 above?
Thanking ou in advance,
LP6
User offline. Last seen 10 weeks 6 days ago. Offline
qyestion was 2 week not 3 or 4
Kathy Castle
User offline. Last seen 6 years 11 weeks ago. Offline
Hiahab all you did was copy mine
use the start and fiinsh dates do not use early and late
Display all rows            ParameterIs               Value                HighValue
Where               Start is within range of           DD                    DD+2W
Or                     Finish is within range of         DD                    DD+2W
Or                Activity Status                           equals                 In Progress
Habib Hajjaji
User offline. Last seen 7 years 33 weeks ago. Offline
Why we are using late Finish in this below Filter?????
WhereEarly Startis within range ofDDDD+2W
  OrLate  Finishis within range ofDDDD+2W
  OrActivity StatusequalsIn Progress
In My Opinion below filter is enough.
this shoud do it
Display all rowsParameterIsValueHigh Value
Nigel Hussey
User offline. Last seen 7 years 49 weeks ago. Offline
mohamed abdelhady
User offline. Last seen 5 years 5 weeks ago. Offline
Hi all , I need to ask how to make a aevised plan using primavera or recovery plan ?
mohamed abdelhady
mohamed ezat
User offline. Last seen 9 years 51 weeks ago. Offline
hiiii  all
  concerning  schedule  update   i'm   facing  problem  at   cost  loaded
after  entering  the  actual  percentges  for   activities   i  found   the  cash flow  values  for  baseline   changed  and  i'm  sure  that  i  didn't  change  the  dates  for  baseline
i  appeared  the baseline   separated  and  checked   the  values  of  cash flow   i noted  that it  became  true    but  after  assigning  the baseline   to  my  updated schedule   the   cash flow values   are  changing
plz if  help  if  you  can  and  tell  me  what is the reason
thanks
L P6
Irfan,
 Thanks for commenting. Yes, your suggestion is certainly helpful especially using the "is within range" term.
I aslo wanted to know if it was necessary to aslo incluse a similar "where" clasue for the Finish date and for activities "in progress". I read on another forum that a look ahead schedule should show:
  • all things starting within the look ahead period
  • and finishing within the look ahead period,
  • as well as all things that are in progress withign the look ahead period.
Do others agree with the above? If  meeting all three criteria is the correct protocool would the following filter be suitable?
Display all rows Parameter Is Value High Value
Thanks all,
LP6
Irfan Khan
User offline. Last seen 35 weeks 13 hours ago. Offline
In Primavera P6 ver. 7 have built in filter of Two Week Look Ached Schedule.
If you want to make in manually so here is the procedure of Two Week Look Ahead Sche.
Go to in Filter > Click New > Give a title of your filer > than chek the perameters like this < Where = Start > in within range of > Value = DD > High Value = DD+2W.
Hope this ill help u.
regards
