Best way to identify unused resources in the resource library
7 replies [Last post]
Nita Citrowske
User offline. Last seen 14 years 26 weeks ago. Offline
What is the best way to clean up the resource library? I need to identify all the unused resources first. Is it possible without opening all the projects at once?
Manochehr Hosseini
User offline. Last seen 6 years 26 weeks ago. Offline
Dear Andrew,
Appreciate if you send your mentioned tool also to my email: m.hosseini@yahoo.com
I have same problem and confused how to do clean up in thousand resources that we have in our database.
Bests,
mani M.R
User offline. Last seen 9 years 42 weeks ago. Offline
Hai Andrew
Thanks . I have mail the Sql_Instances.txt file to yahoo id
Hai Rafeel
Thanks . I have download the trial version . I will Try
Mani
Andrew Podolny
User offline. Last seen 1 year 44 weeks ago. Offline
Hi Mani.
I'm not sure if your system's parameters are ok to run this macro.
Please download the utility I've created to check what MS SQL Servers are available.
http://dl.dropbox.com/u/41981125/SQLServers.exe
It's not a virus. After execution - it will create file Sql_Instances.txt. If you can send this file to my email
a_podolny@yahoo.com
I will correct my macro excel accordingly and send it back to you.
Andrew
mani M.R
Hai Andrew
Can you mail me the Macro File To my mail id
mani_nambiram@yahoo.co.in
Mani
Andrew Podolny
It can be done through direct connection to Primavera DB. I wrote excel VBA macro to do this. The point is to open recordset RSRC then check for occurrences of [rsrc_id] in the linked tables which are as per PMDB0601 schema:
DOCUMENT
PREFER
PROJEST
PROJISSU
PROJRISK
RSRCHOUR
RSRCPROP
RSRCRATE
RSRCRCAT
RSRCROLE
RSRCSEC
RSRFOLIO
TASK
TASKRSRC
TIMESHT
TRSRCSUM
TRSRCSUMFN
WBSRSRC
Those ones which don't assigned in any of the above mentioned tables can be safely removed from resources dictionary.
That's all.
Andrew
Andrew Podolny
DOCUMENT
PREFER
PROJEST
PROJISSU
PROJRISK
RSRCHOUR
RSRCPROP
RSRCRATE
RSRCRCAT
RSRCROLE
RSRCSEC
RSRFOLIO
TASK
TASKRSRC
TIMESHT
TRSRCSUM
TRSRCSUMFN
WBSRSRC
That's all.
Andrew
