Adding Columns in WPs & Docs + assigning Activities to
Ciamak Mir-Eschghi
User offline. Last seen 4 years 47 weeks ago. Offline
Hi Everybody,
1.) Does anybody know how and if at all it is possible to add columns in the WPs & Docs section. I mean other than all the columns (13) that are already available when you costumize the columns.
2.) Is it possible to import through SDK or API from an Excel file al list with all the WPs & Docs (and the information for the columns)and Activities the WPs & Docs are assigned to?
Thanks for your help!
Ciamak Mir-Eschghi
Thanks for the info. Great help.
Ian Nicholson
User offline. Last seen 15 years 13 weeks ago. Offline
You can add User Defined Fields to the WP and Docs module (Enterprise/User Defined Fields).
I am pretty sure that the API supports access to WP and Docs. As a rule of thumb, if you can access something in the web tools (MyPrimavera), you can access it through the API.
You could also import WP and Docs using the XER parser from the Primavera knowledgebase.
Run, don’t walk from the SDK!
