Regarding Import Export (3.5.x software)
Anbin Ponnith
User offline. Last seen 9 years 17 weeks ago. Offline
Dear All,
I tried to import resources using Import Export (3.5.x) software.After exporting to xls format and then importing it it shows an error:
Undefined format found in this .XLS,
Also when try to open the exported .XLS file it shows the file is not in proper format or it may be corrupted.
Also Is there any option in selection tab to add activity code in the Field Box.
I am using P6.0 software.
Please give a solution.
With Thanks & Regards,
Anbin Ponnith
Anbin Ponnith
Dear Chyn,
Thanks for the Reply.But the error doesn’t show it.I just fill the same column exported via the software.But it not getting imported.
Is there any other solution.
Anbin Ponnith
Zq qz
User offline. Last seen 13 years 26 weeks ago. Offline
check the number of column in your P6 data maybe it exceeded xls column.
