Multiple Float path in P6
6 replies [Last post]
Joel Villanueva
User offline. Last seen 1 year 22 weeks ago. Offline
Hi All,
Which Float should I use to calculate multiple float paths by Total Float or Free Float? Which of the two methods is better? Thanks.
Joel
Khuong Do
User offline. Last seen 2 years 28 weeks ago. Offline
I also wrote an article regarding use case of this function.
If you're interested, kindly read it here : https://doduykhuong.wordpress.com/2016/01/12/create-critical-path-for-any-activity/
User offline. Last seen 1 week 1 day ago. Offline
10-4
Joel Villanueva
Hi Rafael,
Thanks,this is a very informative site understanding logest path & slack calculation.
Joel
Whichever in P6 uses Longest Path and Open Ends as critical.
http://scheduleanalyzer.com/sa_long_theory.htm
Joel Villanueva
Thank you Arnold, as I understand from your reply, if I will to define my critical path as the longest path free float will be used and Total Float if Critical path is defines by Total Float. Please correct me if I’m wrong?
To All PP’s,
Can anyone please tell me which is the better method that gives better chances of identifying likely causes of delay?
Joel
Arnold Puy
User offline. Last seen 9 years 37 weeks ago. Offline
Hi Joel,
If you will use Total Float then this is used to identify critical paths based on the total float of activity relationships.
While Free Float is used to define critical float paths based on longest path.
It’s up to you which one you will apply.
Arnold
