Dieter is correct, if ever possible export and PDF to your citrix server. A typical server setup is that both your application and your schedule file reside on the same server. So what you see on your PC is best described as a picture of what is happening on the server. In other words all the algorithms when you reschedule your file are on the server and not being transferred via net work cables from your server to your PC and back. Keeping your data on the server keeps all calculations local to that server and much faster.
We run P6 on a dedicated server so that seems to help with the speed as well. Currently we are experiencing little or no problems with regard to running a citrix environment.
Trevor
24 years 5 months
Member for24 years5 months
Submitted by Jose Valdez Marcos on Thu, 2009-02-26 08:15
Time for export is one of the items in my previous post. Do export only into the Citrix environment, then via Windows explorer to your pc - analogue for import. IT has to install a home directory for you within the Citrx environment. It seems that P6-export and Citrix block each other if you export directly onto your pc.
By the way in Germany many companies use Primavera through Citrix.
24 years 5 months
Submitted by Jose Valdez Marcos on Thu, 2009-02-26 03:09
Thanks for sharing your Primavera experience in Citrix environment. Good to know that P6 is working ok in your case, which is quite reassuring.
Going back to the imported project in Citrix, no, I didnt reschedule and after I rescheduled, my weightage still exceeds 100%. Yes, maybe due to rounding.
Another instance, when I tried to export the project to my local drive, its taking soo long (more than 1 hr. and still exporting) until my pc got hung up and I shutdown my pc. I thought the server is busy. As I am getting used to working in Citrix, I have to log back to the server from time to time.
Jose
18 years 9 months
Member for18 years9 months
Submitted by Dieter Wambach on Thu, 2009-02-26 02:00
Some years ago I worked with Primavera under a Citrix environment. Where I’m working now, we transferred to Citrix last November. After all IT related items are solved, it works ok.
Typically these items are:
- Routing for printouts
- Import/export from/to the server then move to local pc via explorer
- Country settings
- Access rights (A fight against Citrix admins who like to be much too restrictive.)
"100% fool-proof and working properly": As the biggest program error in general is between two ears and sitting in front of a pc or terminal, 100%-foolproof is impossible.
Our environment is working properly.
The weightage of more than 100% sounds nice. It reminds me to election results in communist countries. I’ve never seen in Primavera. Did you reschedule? Maybe it was rounding due to different settings of the environments - your pc and citrix server. I have no idea.
16 years 7 monthsRE: Migrating from P6 Standalone on to Citrix Server
Trevor
24 years 5 monthsRE: Migrating from P6 Standalone on to Citrix Server
Dieter,
Thanks for help. Ill try to contact our IT and see if we have an existing home directory within Citrix environment for P6 export.
Jose
18 years 9 monthsRE: Migrating from P6 Standalone on to Citrix Server
Jose
Dont worry for P6 under Citrix.
Dieter,
Jose
Jose
- Country settings
Good luck
