This is an item for your Database Admin. All db systems have a log-file to do a rollback (into a certain stable status) in case of crash or other difficulties or simply an "undo".
"Full" in general can have those reasons:
1. Server run too long time without stop and restart (MS SQL Server)
2. Technical problems e.g. network not stable --> many retries or a technical equipment within the network damaged
3. Wrong parametrization of the database
4. If you have an interface to e.g. SAP: program error.
18 years 5 monthsRE: database ’PMDB10’ is full. Error code PRMDB-2035-6
Theres a primavera bulletin on this
Check solution No. 200363104250
U need to shrink the log file
Thanks Dieter,
I thought its a error from my side. But, apparently, Admin has completed the required things.
Thnaks Neway, for the help
18 years 9 monthsRE: database ’PMDB10’ is full. Error code PRMDB-2035-6
Raviraj
P6 shouldnt be the reason.
Good luck!
