Primavera P5 standalone installation
7 replies [Last post]
Muhammad Fiaz
User offline. Last seen 1 year 33 weeks ago. Offline
I am installaing Primavera P5 standalone on my computer with windows XP but during database configuration it fails to configure MSDE server.How do i deal with this problem.Will somebody suggest.
BIPRESH PAUL
User offline. Last seen 2 years 51 weeks ago. Offline
Same probs happens with me, I could not install P5 neither in Vista noe in XP. ne1 for help??
Muhammad Fiaz
Dieter:
Thanks for your time and mail. I disabled Firewall and successfully installed satndalone P5 and now running it.
Dieter Wambach
User offline. Last seen 7 years 43 weeks ago. Offline
Muhammed
Obviously It was too early for me in the morning and I didn’t read your question correctly. Sorry.
Possible reason 1: You need local Admin rights on your pc and don’t have them. Easiest way to check: Right click onto the start button. If the bottom line of the new window is "Explorer All Users" you have them.
Possible reason 2: It seems that there is a conflict with an older version of MS SQL Server. Check if it is still required. If not, deinstall - don’t forget to check the registry - and try to install P5 again..
Dieter Wambach
Thanks Ronald
Absolutely correct! P5 works under XP and NOT under Vista.
Ronald Winter
Dieter,
I believe that you meant to say that P5 cannot be installed under Vista operating system. My P5 ran well on my XP computer.
Dieter Wambach
Muhammad
In PP you can find some threads on this topic. P5 cannot be installed under XP. You’ll have to upgrade to P6.
