Help for Global change in P6
8 replies [Last post]
Girish Batolar
User offline. Last seen 43 weeks 3 days ago. Offline
I want to perform a global change in P6. I want to add a charectre in fornt of the Activity ID.
Could some one please suggest me the steps.
Did you try edit>replace!!
Girish Batolar
Thanks Guys
Appericiate all the help. Any way found out how to do it the easiest way in 2 minutes by using global change
SubString(Parameter,#,#) function
Dieter Wambach
User offline. Last seen 8 years 10 weeks ago. Offline
Why don’t you simply try:
IF: Your condition / filter or leave blank if for all activities
Then: "Activity ID" = X (i.e. the character you want to add) & "Activity ID"
Satya Narayana
User offline. Last seen 11 years 27 weeks ago. Offline
Export along with the relationships, you will have 2 sets of activities when you import back, delete the first set by fitering/sorting.
Hope this works
Oliver Melling
User offline. Last seen 5 years 40 weeks ago. Offline
Groups: The GrapeVine
Export the project file into excel.
Copy the activity id column into ’column B’ in a new spreadsheet.
In ’column a’ put the prefix you want to put in front of your activity id.
In ’colum c’ type the formula =’column a’&’column b’
Drag this down so that it is done for every activity.
Copy ’column c’ and paste special values back into the exported project file.
Save it, then import back into primavera.
Girish Batolar
Hi Oliver
Thanks but this will not work as i have the logic already defined and by what you are telling me will only create new id in primavera.
I wanted to know the steps for adding a charecter in fornt of the activity ID using Global change.
Can any one give me the steps.
Oliver Melling
Exoprt the project into excel, change the activity id, then import back into primavera.
Ronald Romero
User offline. Last seen 1 year 46 weeks ago. Offline
Hi Girish,
try to play around with the given Modify Activity ID’s example of P6. You can you this function to extract text from you Activity ID which are Substring, Rightstring and Leftstring.
