IMPORT P3 PROJECT TO P6 IS PAIN....BIG ISSUE
Suresh Sankaranku...
User offline. Last seen 5 years 28 weeks ago. Offline
HI Dear Friends,
I am facing a big problem of importing the p3 (project planner 3.1) project to p6 6.1 version. The problem is the original budgeted units are getting huge difference in p6.
I tried to import a proj into p6 from p3. In p3 the budgeted unit was 90hrs and but when i imported it into p6 its give 800hours... I been ......f....d in the meeting ...I just thought p6 is reliable and wont make me wrong..............
Pls if you have any clue pls share....
Thx
Suresh
Dieter Wambach
User offline. Last seen 7 years 43 weeks ago. Offline
Suresh
If you walk through the import you see a window "Update Project Options". Select "Advanced" in the bottom of this window. Then try "units as hours".
Sorry, one of your sentences I don’t understand: "... in p3 is 4 duration is 10 days". What do you mean by this 4 = 10 ???
Diater,
The units are same in p3 and p6. What i found is.. Unit per time in p3 is getting wrongly calculated in the p6
Eg: 8hrs per day calender
unit per day is specified in p3 is 4 duration is 10 days
In p6 it converts like this
4*10=40*8 = 800h i dont knnow how its come.. but i think this is the funda... bullshit p6..
Dieter Wambach
Suresh
Just two ideas:
1. Parameter Planning Units: Hours or Days: May be you selected days but planned in hours.
2. Resource curves: Sometimes not really compatible - e.g. "curve A" bell shaped in P3, triangle in P6.
May be others have more ideas.
