Login issue with P5
6 replies [Last post]
Karim Mounir
User offline. Last seen 11 years 12 weeks ago. Offline
Hi, I copied the database which I use at my desktop and transfered it onto my laptop (company), then I "Attached" this database using the SQL Enterprise Manager. I configured the connection with P5 using the company’s license and it succeeded, I logged into P5. The problem that I’m facing is whenever I try to login again into P5 an error appears stating that the user name is already logged in. what is wrong? Thanks, Karim
Ilter Aydin
User offline. Last seen 8 years 24 weeks ago. Offline
Reinstalling server may solve the problem but if you have realtime data in your system it maybe harder. Instead, after you are sure that nobody is logged in, you can open SQL enterprise manager/USESSION table and delete all the active lines. This is the easiest way.
Karim Mounir
reinstall P5, it did work
Shahzad Sikandar
User offline. Last seen 7 years 20 weeks ago. Offline
Imran please explain your answer in detail,
reinstall what?
Imran Arshad
User offline. Last seen 7 years 7 weeks ago. Offline
Re-Install then probably will help.
Karim Mounir
I created a new user account when I was able to login but the same issue occurs, an error appears stating that the user is already logged in?
Imran Arshad
Get a new login & password from your administrator & check.
