Updated ImportExport Utility for P5
David Smith
Hi All,
I have a Excel utility that I had sent to me from Primavera Support while I was at the Primavera conference. It said in the email that the tool has not been updated for P5. Has anyone updated this utility for P5? If you have one can I get a copy of it? If not does anyone know what needs to be updated?
I would be grateful for any help or direction on this. I am willing to open the hood on this thing if necessary.
This is what the utility can do:
Activity.xls is designed to facilitate Import and Export of the following:
Activity Details (General Activity Information)
Activity Relationships (Predecessors and Successors)
Activity Code Assignments
Resource Assignments
Activity Steps
Activity Expenses
Activity UDF (User Defined Fields)
Resource Assignment UDF (User Defined Fields)
Activity Step UDF (User Defined Fields)
Thanks In Advance
David
K D
User offline. Last seen 17 years 2 weeks ago. Offline
you can go to POINT and search for prim4617.
Hemanth Kumar
User offline. Last seen 2 years 17 weeks ago. Offline
Install SDK ( If not Installed )
Explore P5
You Have 2 Excel Templates
Sandy Matheson
User offline. Last seen 12 years 10 weeks ago. Offline
P5 has export/import facility to/from .xls files but it is fairly laborious with each step to be completed each time. But it works.
User offline. Last seen 15 weeks 2 days ago. Offline
David,
The RA excel utility Activity.xls is mean for P3x only. P5 use SDK API which is included on your P5 installation CD. You can use xls import/export function in P5 which doing the same thing but limited function.
HTH,
Rodel
