Enterprise Database backup & restore
Luca Basile
User offline. Last seen 10 years 21 weeks ago. Offline
Groups: TILOS
Can any one help me and give me a step b step guide line on how to backup and restore the P5 database?
L
K D
User offline. Last seen 16 years 38 weeks ago. Offline
Hi Andrew.
This backup solution will need a SQL skill to reattach the database. I think not much people know it.
So we should just use it in case our OS crashed, and we can copy those file in DOS environment.
Andrew Podolny
User offline. Last seen 1 year 51 weeks ago. Offline
Another method with MSDE SQL & Primavera 5 is follow. Close Primavera 5.
Goto Start->Run..
In window type services.msc ENTER
Locate SQL Server (PRIMAVERA) right click and select stop.
Don’t close the services window.
Then open My Computer and browse for path
C:\Program Files\Microsoft SQL Server\MSSQL$PRIMAVERA\Data
Copy databases:
pmdb$primavera_DAT
pmdb$primavera_LOG
mmdb$primavera_DAT
mmdb$primavera_LOG
to a secure place.
* Note - the path and names may vary based on your setup configuration
Start SQL Server (PRIMAVERA) again by right click and select Start. Close Services window.
If you are already upgraded to Primavera 6 - the things are much easier in SQL Server Management Studio Express environment.
Andrew
liu yi
User offline. Last seen 16 years 34 weeks ago. Offline
thanks a lot .I am learning from you !
Dieter Wambach
User offline. Last seen 8 years 10 weeks ago. Offline
Hi Luca
have a look into this thread:
http://www.planningplanet.com/forum/forum_post.asp?fid=1&Cat=8&Top=39078...
If you’ll have any difficulties, ask again and give the error message.
Good luck
