Project Status P3e
Core Mirror
User offline. Last seen 18 years 18 weeks ago. Offline
What database table and column indicates if the project is open or closed?
Thank you
User offline. Last seen 25 weeks 5 days ago. Offline
Hi Core,
You may want to include into your link the TASKRSC table and use rscs_type to filter the “RT_LABOR” only to separate from materials and equipment hrs.
Rodel
Core Mirror
It was the table names and columns thank you.
What I am trying to run is a query to get the total planned and actual hours for 2007 for active projects, but some of the projects are coming up with double what the hours should be and others are very close to what they should be. I tried using (<> WS_Closed) but that did not work. If I use (= WS_Open) some of the projects show half of the hours they should be showing.
This is comparing to the report ran in Primavera
Core
Dieter Wambach
User offline. Last seen 8 years 11 weeks ago. Offline
Hi Core,
maybe your question was, if a project is loaded into your PC’s memory.
Either column "open state" under the category summary or in the top line of the Primavery window - if not too many loaded.
If you are referring to Project Status:
Table: PROJ_WBS
Column: status_code
If Check Out Status:
Table: PROJECT
Column: checkout_flag
Rodel
