Importing P3 projects - activity codes
Neal Carter
User offline. Last seen 13 years 15 weeks ago. Offline
Hi everyone.
We are doing a lot of migration of projects from P3 to P5 and are concerned that the activity codes are made global automatically. Is there any way that we can ensure that the codes are either EPS or Project codes?
Neal
Chris Radecki
User offline. Last seen 7 years 48 weeks ago. Offline
On the question, a RAG way be to use xerFileParser&Builder.xls from P3 POINT site.
Setup projects with activity codes and dummy activity codes value, export them to xer, use the above xls to split the activity codes
Cannot remember how to export activity codes from P3, but sure there is a way.
Copy to the xerFileParser&Builder.xls and convert to xer and import.
Sorry that it is RAG.
Chris Radecki
Take care with activity codes at EPS or Project level. I am not too cluey on importing them, but....
There is a glitch with Puge Deletes in 5sp1/0 where EPS or Project level activity codes can bedeleted from the activity ID assignation.
I like the codes at EPS/Project level - just have to accept that have to export/backup the acivity assignation, and reimport when they are lost.
Maybe SP2 solves this problem; not using purge deletes seems also to work at present ;-)
Sufian Malik
User offline. Last seen 18 years 10 weeks ago. Offline
Additonal information:
When going through the import :
1)If you select ’combine sub projects’ then the project codes are added in the activity codes dictionary at a project level
2)If you select ’create separate projects’ then they should be added at a global level.
Sufian Malik
Hi there
When importing a project, activity codes are added in the project dictionary of activity codes
Sufian
