Text Label Characters P3e version 4
Donovan Govender 👤 Member for 20 years 8 months
right click in bar area,click modify,click lable,click in data column,click down arrow,click on log record,it will remove act. descrip. from bar,click the act. no.,f7 on key board,click on log and fill in your notes
Donovan
N
Niek Zonneveld 👤 Member for 21 years 4 months
Peter,
Go to [Bars...] and select the tab [Bar Labels].
If you then select the upper bar and scroll down through your bars (one by one, with [arrow down]), you’ll automatically find the bars that have a label. Remove these, and you are done.
H.T.H.
Niek.
J
Julie Scully 👤 Member for 20 years 8 months
Peter
You need to go to the View menu -> Bars, then select the relevant bar/s and delete the ’Activity Description’ bar label (bottom of screen).
Julie
P
Peter Raybould 👤 Member for 20 years 3 months
The problem is the activity description appears in the gantt chart area right of the bar. I have tried removing this by reducing the limit text label characters but the minimum value is 1. This interferes with other labels I wish to apply to the barchart. Do you know how to remove the activity description from the barchart.
Featured Partner
NinaKay
Tri Puji Heriyanto
Nurtan Yerbolek
Larry Cebuano
fridau
Patricio_aoa
jeoffrey reyes
Zine Eddine
mxsiegel
