export & import database from p3 to excel and
saif ansari
User offline. Last seen 18 years 39 weeks ago. Offline
hi friends,
i am new p3 user, can anybody explain me the method of exporting the database from p3 to excel and importing back from excel to p3 step by step so that i can follow.
thanks
User offline. Last seen 10 weeks 4 hours ago. Offline
do you mean export a project not the database
P3 uses lotus wks, wk1 or dbf file formats for importing and exporting data.
unless you have an older version of excel that can save a file as a wks wk1 or dbIV
you can export the file and open it using openoffice but open office will not save it in wks wk1 or dbIV proper format
as Jonathan has pointed out you can download lotus from here
https://archive.org/details/LotusSmartSuite99
one you have this installed
open P3 and open your project
select Tools
Project Utilties
select Export
select Add
give it a new number like Ex-13
on the content tab select what data you want to export activity ID, original duration  etc
on the selection tab select what you want to export (like a filter) i.e. Activity ID EQ XXXX
on the format tab in the Name box give it a file name i.e. C:\P3win\P3out\MYDATA
on the format tab in the Type box select WK1
next select Run and you wil see what you have exported
open in Lotus Smart Suite Lotus 123
select File Open and go to C:\P3win\P3out\MYDATA.WK1
Modify the data that you want changed
next select file save as then for the Save as type select Lotus 1-2-3 (WK1)
it will ask you about saving as an earlier version select OK
go back into P3
select Tools
Project Utilties
select Import
select Add
give it a new number like Ex-12
in the Enter Path and input file box type in the folder location and the file name C:\P3win\P3out\MYDATA.WK1
Select Run
and it will show you what activities have been updated
Jonathan Goldsmith
User offline. Last seen 5 years 1 week ago. Offline
Wow, this is an old one. The best tool to use for importing and exporting from P3 is to use Lotus Smart Suite Version 9. You can download it from here:
I've never got importing and exporting from/to Excel to work correctly in P3. You may have to spin up a VM with Windows XP / Windows 2000 pro to get it to work, but if you're still using P3 you're probably doing that already.
I have no clue how legit that link is, it just came up in a quick google search. Download at your own risk!
Mertz Balanon
User offline. Last seen 1 year 14 weeks ago. Offline
Groups: GPC Qatar
Thats really my concern also as I need to export my percentage and budget cost to excel and do the S-curve..How to exprt & import ..
Marcio Sampaio
User offline. Last seen 12 years 19 weeks ago. Offline
Hi ...
I can find it on P3 forum. Look for in old threads.
Regards.
