Adding Column Data
6 replies [Last post]
Leonardo Caoile
User offline. Last seen 3 years 21 weeks ago. Offline
Hi Guys, would appreciate any response on this one.
I'm just a newbie in using P3. I tried to insert columns other than listed in the column data. It says "blank column" on the data but I wanted to use: "total quantity", "UOM", and ""production rate".
Somehow I have managed to have the columns with the said title but I am not able to input any data in its cells. It seems that the cells are being locked or some sort of being disabled to revieve data. I wish to have these data in my layout for determining the required man-days for each activity but how will I proceed?
Maybe you are using Windows 7 64 bit.
http://www.pmsite.com/Forum/tabid/159/aft/630/Default.aspx
https://forums.oracle.com/forums/thread.jspa?threadID=1091475
http://www.planningplanet.com/forums/primavera-project-planner-p3/421498...
I understand Primavera/Oracle no longer sells P3, it makes sense it was developed for older operating systems and they moved to an application designed to work on modern operating systems. I do not blame the operating system nor Primavera/Oracle but those who insist on using P3.
Get over it.
Leonardo Caoile
Yes Gary, that is what I've expected also. But I cannot type in any data in the cells. Maybe I need to re-install the software.
Thanks Mike!
Gary Whitehead
User offline. Last seen 5 years 25 weeks ago. Offline
Mike is right that you cannot copy & paste info from, say, excel to the column.
But you should be able to just click on a cell and type in the data -I thought that was what you wanted to do?
User offline. Last seen 36 weeks 11 hours ago. Offline
Hi Leonardo
The columns show the data in the programme.
There is another route to add the data to the programme tasks - maybe from an excell import process.
You can't just copy paste data like you can in PowerProject.
Mike Testrp
Leonardo Caoile
Dear Gary,
Thank you for the instructions. I already created those columns. But still, why can't I place a value on its cells? It seems that the cells are somewhat locked for data entry.
Have a blessed day!
Leyo
Gary Whitehead
Before yoiu insert the columns, you have to create them first.
Go to data > custom data items and create your total qty, UOM and production rate data items.
The "Type" will be either N (numerical) or P (numerical with decimal point)
Length is max number of characters you will need to use
Once you've finished here, you should see these new data items as available columns to insert from the format > columns window.
G
