SureTrak Questions
Treighton Mauldin
User offline. Last seen 14 years 25 weeks ago. Offline
I am trying to create a Master Project with 3 Sub projects in SureTrak for a $700M Hospital Master Plan Project in California.
I have never tried to create a master project/sub project environment in SureTrak. Can anyone help me out?
User offline. Last seen 2 weeks 4 days ago. Offline
10-4
Treighton Mauldin
Thanks! i figured it out, i was not sure that using a project group would allow me to have interproject links and allow multi user access to the sub projects.
but it does and so far it is working...
again thanks!
Treighton,
Welcome to PP.
Assuming you know how to work stand alone jobs in SureTrak:
>Use SureTrak help looking for the keyword "Group".
>Then, Investigate Apex Sample Job, it will give you some clues by mere observation of project naming under Project Properties of the Project Group and Member projects.
>Now you are ready to start: Start by Creating your Project Group, this will be your Main Job where you will add your activities for the main job. Then Create/Add your Member Projects. -Use the same planning unit on all jobs.
