Which Files To Remove To Get a Clean P3 Uninstall
kafo souq
User offline. Last seen 15 years 50 weeks ago. Offline
Dear all
Thought of sharing this with you all
When you want to uninstall P3 (for whatever reason) and you want to remove it completely there is a method to do this.
First: Uninstall P3 Using the Uninstall utility - From Program Window
Second: Look for File Name (P3.ini) and delete it.
Third: Look for a file Called (BTI.ini)and delete it.
Forth: Look for files called (Wbtr*.*) and delete them (9 dll files and one exe file)
Fifth: Look for Field Called (W32mk*.*) and delete them - Be careful in Windows Vista for this Count the number of files. (They are 4 DLL files, 4 EXE files and 2 HLP files)
Six: Then Delete the folder called (P3WIN) from your drive C:\, D:\ Etc
Seven: Restart You computer
Eight: Your installation is now ready to begin and you P3 will never recognize that it was previously installed on this machine
Hope This Helps Some of you :)
Alaa Salih
User offline. Last seen 15 years 12 weeks ago. Offline
Thanks Kofa....this was helpfull
