Java Application ERROR in P6
13 replies [Last post]
James Braghini
User offline. Last seen 14 years 6 weeks ago. Offline
Has anyone had a problem when updating the baseline having an error message coming up stating "Error running the selected application: C\Program Files\Primavera Common\Java\_jvm\bin\java.exe? I went to our C drive and found the flow for this but could not see any problem.
Any suggestions from the forum?
James Braghini
User offline. Last seen 2 weeks 6 days ago. Offline
so the path is correct
Divya Tripathi
User offline. Last seen 6 years 1 week ago. Offline
Hello James,
Make sure that the directory has read and write rights. after that, you may proceed further.
George Ridulme
User offline. Last seen 12 years 30 weeks ago. Offline
Hi Guyz,
Just to share with you that my Java application error just got solved. Im not sure if this error is somewhat connected to changing of login name on admin preferences.
I noticed that i encountered this problem when I started changing the login name with another name. This afternoon, I just return back all the default setting and it just work fine, as if nothing happened.
Thanks again for your continuous support.
george
Arnold Puy
User offline. Last seen 9 years 42 weeks ago. Offline
Hi George,
You can back up your database. Go to Program --> Microsoft SQL Server 2005 --> SQL Server Management Studio Express. However, if you are using Windows Vista I guess there is a problem during back up. It happened to me, but if you are using Windows XP then it works fine.
Arnold
George Ridulme
Hi arnold, thanks for your prompt reply. Ive just checked based from your suggestion & its still the same.
Can’t figure out why did this happen.
If i have to reinstall my P6, how do I back-up all my files in such a way all the format i did on the EPS will still be same...
Is there any other way...
Thanks & Regards,
George
Arnold Puy
Hi George,
It also happened to me but I tried to apply my Post #5 and it works fine.
Arnold
George Ridulme
Hi there,
I recently encountered this problem. Does anyone have a fix solution for this.
I cant update my baseline at the moment.
Please help.
Thanks in advance.
George
Arnold Puy
Hi Rav,
I am not familiar with this code. I have an experienced with the said error, when I tried to check this code from my desktop I changed the code in my laptop and it works.
Anybody has an idea??
Arnold
A D
User offline. Last seen 4 years 1 week ago. Offline
Hi Arnold,
I have checked the parameters on my machine and it says
-Dprimavera.bootstrap.home="c:\Program Files\Common Files\Primavera Common\Java" -Djava.ext.dirs="c:\Program Files\Common Files\Primavera Common\Java\lib;c:\Program Files\Common Files\Primavera Common\Java\_jvm\lib\ext" -Dapi.schedulecomparison.brand=ECC -Duser.region=$COUNTRY -Duser.language=$LANGUAGE -Dlogin.username=$USER -Dlogin.password=$ENC_PASSWORD -Dlogin.dbName=$CURRENT_DBNAME -Dupdatebaseline.projectId=$SELECTED_PROJECT_ID -Dupdatebaseline.baselineId=$SELECTED_BASELINE_ID -Dapp.name="$APPNAME" -DautoLogin=true -Dupdatebaseline.autoUpdate=true -jar "c:\Program Files\Primavera\Project Management\Baseline Update\prm-updatebaseline.jar"
Will you plz guide, what exactly this code is?
Arnold Puy
Hi James,
Try to check your registry.
Go to Start then "Run.." Type regedit, then click OK.
HKEY_LOCAL_MACHINE/SOFTWARE/Primavera/Shared/Update Baseline.
Double-click PARAMETERS.
Navigate to the following location: HKEY_LOCAL_MACHINE/SOFTWARE/Primavera/Shared/External Applications/Update Baseline
Double-click PARAMETERS:
Then try to check the starting, should be like this:
-Dprimavera.bootstrap.home="C:\Program Files\Common Files\Primavera Common\Java"
Arnold
Arend Kok
User offline. Last seen 10 years 46 weeks ago. Offline
James Braghini
Hey Richard maybe some of us think that if someone is using P3 they may also know P6. Sometimes people look at both forums. Just ignore us.
James B.
Richard Rush
User offline. Last seen 9 years 51 weeks ago. Offline
Just what has this to do with P3?
PP Admin - can we keep these forums in order??
