Delete reflection project
Rick Aquino
User offline. Last seen 14 years 14 weeks ago. Offline
Hi All,
How to delete or remove reflection project?
Thank you
Arnold Puy
User offline. Last seen 10 years 3 weeks ago. Offline
Hi Rick,
You mean the "Delete Command" is Locked? I assumed that your project is in "Checked Out Status". Try to change to Checked In Status.
Arnold
Rick Aquino
Hi Arnold,
Yes i did! but the "delete" word is not highlighted, that is why i cannot delete the reflection.
Best Regards
Arnold Puy
Hi Rick,
To delete Reflection, go to Projects --> select the reflection project you wanted to delete and right click and select delete.
Arnold
Rick Aquino
Thank you Pranab, however, i’m talking about P6, how to delete "reflection" in P6.
Pranab Kumar Deb
User offline. Last seen 3 years 37 weeks ago. Offline
Hello Rick ,
By reflection project i assume you mean target.
1. Remove target Tools>Project Utilities >targets , then select the target from the target column and click the " - " button, click ok .
2. Then go to Tools>Project Utilities > Delete , select he correct project and delete it.
HTH
Pranab
