Primavera 3.0 to pdf format
Jun Gallardo
User offline. Last seen 9 years 20 weeks ago. Offline
Can anyone help me convert my Primavera 3.0 print-out to PDF format. I have an adobe professional 7.0 installed in my PC. I can only convert documents under MS excel & word but could not convert primavera. In converting MS Excel & word, I change the printer setting to ADOBE, is this applicable also with primavera 3.0? It is not working.
Roli Rafa
User offline. Last seen 16 years 44 weeks ago. Offline
Jun,
Just want add something to other’s reply.
As far as I know, Adobe Acrobat 7.0 Pro has some difficulty in printing P3 outputs specially if you put some logos other than those coming in bundle with P3. What I recommend is Adobe Acrobat 5.0 which comes with 2 printer drivers, a pdf writer and a distiller. I normally use the distiller whenever I have some graphics embedded on the schedule. So far the 2 programs works happily with each other without complications.
The other pdf writer you can use is the freeware CutePdf program. It also prints P3 with no problem at all. That is as far as I know.
Lastly, check your version of P3 if it is already SP3. If not, you can get the patch from Primavera on their Knowledgebase.
Hope this helps,
Jun Gallardo
Mr. Olike, I already did this but it is not working. Anymore suggestion pls.
Ife Olyke
User offline. Last seen 11 years 3 weeks ago. Offline
... print preview, select your PDF printer, then print... should work ok..
