Primavera Project magement
pierluigi lu
User offline. Last seen 16 years 37 weeks ago. Offline
hi,
someone know how to launch pm.exe direcly to specific project? i know that is possible to launch with login and pwd parameter but nothing about proj_id.
In other case, Is it possible to do this by saving something in the DB?
pierluigi lu
Thanks for your answer,
but maybe this can’t help me because i have to launch pm.exe from another program.
So i have to set the options you refered to programmatically.
is it possible to do?
Maybe i must write somethings in the USERDATA table of the Primavera5 database.
Johny Kesserwany
User offline. Last seen 7 years 45 weeks ago. Offline
Hello,
Primavera project management is not supported by Primavera project Planner...?
In P5 & P6 you have to Set a Startup Options:
Choose Edit, User Preferences, then click the Application tab to establish the default window and dialog box that displays when you start Project Manager and to record the actions you perform in the application to a log file. You can also set options for grouping and sorting. Set startup and log file options Select the window to display each time you start Project Manager. Select Home if your work varies each day; the Home workspace enables you to select the applicable window or layout for each session.
You can also indicate whether to display the Issue Navigator dialog box, which contains outstanding issues that Project Manager generates based on your preset thresholds, and the Welcome dialog box, which enables you
to choose to create a new project, open an existing project, open the last project opened in your previous session, or display global/enterprise data only.
Jk
