Converting project planning units
maurice x
User offline. Last seen 13 years 26 weeks ago. Offline
Hello,
In eed to change a planning setup in hours to a planning in days.
I’ve created a copy with planning unit days and tried to convert the TF and FF Values using export -> divide values by 8 and import, but the FF will not change.
Any suggestions what I can do to convert this project?
Maurice
maurice x
Scott,
This part I know, but that doesn’t change the OD/RD/LAG/FF/TF etc.
Maurice
Scott Hastie
User offline. Last seen 3 years 23 weeks ago. Offline
Hi there,
you could try copying the project, if you go tools,project utilities,copy.
you should be able to select a planning unit when you are selecting the copy To options. i.e hours, days, weeks, months
Hope this helps.
Scott
